My Tow-Pac 14" InstaTrike Install on Ultra Classic Harley
Jim I got it shipped to me from the factory. Took about three weeks only.
I'm still checking it out and I will post my finding as I get them here!
You have to call the factory to order!
Not sure about ETrike.
People love my floor, you can drive an 18 wheeler on it, but can't cut and weld on it without a fire proof blanket! I did my office and music studio with this floor connecting it all to the shop floor but just changed the colors of the 12" X 12" tile!
thanks a ton for taking the time to talk. looking forward to seeing how your project turns out. happy ridding.
jim bob
Fenders, fender steel "T" braces and the rear frame cover is now at the custom paint shop.
This guy does excellent work, to match paint and pen stripe, the two pen stripes have to be painted and is not a sticker.
He will pen stripe them like the bags and paint everything For $750.00 I found that high but the paint alone cost $275.00!
I put a call to the factory rep. yesterday late for him to call me, The reverse motor has only the thickness of two business cards from the tire! That can't be right! I'm thinking there is a spacer missing that would go between the tire's rim and the spindle.
WOW, that's close - that can't be right... Is that a worm gear drive Bob??? I can't quite make out the details of the drive system...
Les
Bob,
thought you might like to see some photos for comparison - this is my Tow Pac cart with the 12" wheels...
rear view of cart
front view of cart
side detail showing wheel down force adjustment mechanism and parallelism adjustment plate
detail showing plug for tailights
detail showing captive nuts for fender
another view of captive fender nuts
Frame and fender brackets were drilled and tapped for 8/32 binder head screws... 1/4-20 captive nuts were mounted with blue Loctite on the screws...
Les
Les
The drive is a small gear like the big one but about the size of a quarter.
Factory guy is baffled. He said he would put one together in his back shop and call me with the results.
It seems to be all new to him.
When I purchased this kit I didn't know I would be the test pilot for Tow Pac for a new product!
If it is not fixed to my satisfaction I will return the reverse and get a stock spindle and then have a reverse put in my Harley transmission!
This one cost an extra $400.00 Not sure what it will cost for a Harley reverse .
Thanks for sending the pictures!
***I just checked on an after market Harley reverse.
they run about $1,500 not installed.
So I need to fix this one! Wife just told me she will NOT be the reverse! LOL!
Les
Good looking Cart! You told me you pull your fenders off for transport and needed a light plug on the cart
and a fast way to put fenders on and off. Looks like you got it together for that.
I will not need a plug here if I can pull the tires without removing the fenders. But I will need a light plug
between the cart and the bike.
Is that a universal plug? I was thinking about a Wal-Mart trailer plug connection, they are not locking but I was thinking
about just taping it together.
I got a Harley plug to tap into the lights under the seat, but will Not use that to remove the cart.
I want to put the quick disconnect at the back of the bike.
I will also need a disconnect for the reverse wires that connect to the battery.
Hey Bob, thanks for the kind words... The Plugs are Hitachi plugs that I ordered from The Electrical Connection... They match other plugs used on the bike and are available in various pin configurations... They are not that expensive and EC has the crimping tool as well... Here are the links...
http://electricalconnection.com/index.php/product-category/shop-gear/shop-gear-connectors-oem/
http://electricalconnection.com/index.php/product/crimper-hitachi-type/
Thanks for the info on their reverse... I have seen it before when I was at their factory some years ago so it is not exactly new but might be newer for your particular configuration... Hope you get it sorted out since you already paid for the kit...
This is how I made the brake and tail light using the same red LED light... Just a couple of diodes and a resistor and it works well and the red LED light now functions as a running light and brake light, getting brighter when the brakes are applied...
Les
Les
Thanks for all your help.
Tomorrow I hope to get back at working on the bike.
Still waiting on answers from the factory and bushings, if they even shipped them.
Looks like I need to buy more wiring stuff to put under the seat to keep the tail lights on the cart from fry N the delicate Harley wiring.
Here are some pictures of some of the adjustments. I have not even studied that yet, But took pictures anyway as I decide what to work on next.
I still need to finish the Tow-Pac frame on the motorcycle, and hope to finish that next.
Hey Bob,
So in the last set of photos, I see the parallel adjustment plates, the down force adjustment, and the lean stop bracket... I assume there are torsion arms somewhere in the suspension but I haven't seen them yet - just asking...
I must say, you are much more patient with Tow Pac than I would have been regarding the issues you have been having... It would seem like Tow Pac is dropping the ball these days in terms of customer service... Just an observation on my part from this conversation and others like it...
My kit is off the bike right now as I have been riding solo on 2 wheels for a time... As soon as the wife starts riding with me again I'll put it back on and I have a trip scheduled for next year down The Blue Ridge Parkway with my daughter and I'll have it on for that as well...
I'll keep watching for additional posts from you - anxious to see the finished product on your Harley... ;);)
Les
The big gear is 7/16" wide and the small gear on the motor is 1/4" wide.
Tow-Pac is telling me to shim the motor to move the small gear 1/8" further down on the bottom picture.
That would make it catch the large gear half way and hang over 1/8" catching nothing.
That would give me less than 1/8" clearance from motor to tire.
I say less than 1/8" because right now the motor is pushing up agents the tire, after torque the lug nuts to 75' lbs
I lost the two business card clearance I thought I had after torquing the lugs.
If I hit a bump or put weight on the tire and it bulges out then it would take up that little 1/8" clearance.
What about a flat or bearing failure or picking up something on the road at 70 MPH? That would rip the motor off it's little mount!
Pure BS coming from Tow-Pac!
Yesterday he told me to call him at my convenience and he would tell me how to shim it or fix it!
I told him I would call this morning and he said fine!
Well I've been calling his cell every half hour all morning with no answer! It's 1:15 P.M. still nothing!
The only thing I think would work is 1/4" wheel spacers and 1/4" longer wheel studs!
That would give me 1/4" clearance. It would move the tire out 1/4" and there is plenty of room for the finders.
I also could leave everything like it is and get a full gear bite on the small gear.
Cost after shipping would be about $40.00 for their screw up!
http://www.jegs.com/webapp/wcs/stor...&submodel=&engine=&Nrpp=&No=&persistYmm=false
I don't know if thats a proven setup or not, but that sure looks like a power window motor. If thats what it is, that little shaft that sticks out beyond the small gear should be supported. Shimming will make it worse. But I think I would shim it out and try it, might just fail on the first try.
Seems to me like Tow Pac dropped the ball on the reverse feature with the 15" tires... It would probably be OK with the 12" tires...
Bob, I still do not see any torsion axles - does your kit have them or are they using a different form of suspension on your kit???
I have the same question. All day I have been try n to contact Tow Pac the guy told me yesterday to call him today.
I just called the office and the lady told me everyone is off today.
She told me it has independent suspension! I got it all in pieces so can't jump up and down on it to check it!
[h=2]DESCRIPTION[/h]
  • Very fast installation and removal for the trike or bike experience
  • No modification to stock motorcycle frame or drivetrain
  • Completely removable for easier resale of motorcycle
  • No loss of ground clearance
  • Independent wheel suspension and adjustability
  • Flat stable cornering
  • Trike stability with much smoother ride
  • Full access to stock saddlebags
  • Easily installed by the consumer
  • Available for over 100 makes and models of motorcycles
  • Minimal impact on fuel economy
  • Available in 8 inch wheel, 12 aluminum wheel, or deluxe 14 inch radial tire package
[FONT=&quot]Our InstaTrike B is a hybrid of our InstaTrike and MiniTrike.[/FONT]
  • Engineered for bikes/scooters who’s frame configuration does not adapt to either
  • InstaTrike or MiniTrike.
  • InstaTrike bolts directly to the frame of the motorcycle but does not utilize a receiver hitch.
  • It is not designed for quick removal like it can be removed with only a few bolts
  • No alterations to stock motorcycle or scooter
  • Appearance similar to InstaTrike
  • Available in 8, 12, or 14 inch wheels
[FONT=&quot]Call today for more information or to place your order! 866-694-3500[/FONT]
I pulled the grade 8 bolts out of the sprocket. My ink pen is pointing to where I may be able to put some half moon, homemade flat washers or shims to mover the sprocket and shim the motor and still get more clearance. But it still seams like Wheel Spacers and longer studs are the answer!
It makes more sense to shim the wheel out to gain the clearance as long as your fenders will still work. But you shouldn't have to be re-engineering a kit when you paid good money to buy a kit that is supposed to be ready to install.
I fount the wheel spacers here in town. Couldn't find the Studs yet I need
1/2-20 x 2" to 2 1/4",
wheel spacers are 5/16" and fit ! I'd like more thread!
Anyway back at the ranch! I will attach the spaces centered on the hub with a drop or two of glue, to keep the wheel in balance til I can get the tire on.
What happen with Tow-Pac? Well they are very friendly and do their best to help.
The reverse was offered on the 10" wheels only and no where on their site does it say other wise.
So I would think someone said,
"Why don't we offer the reverse with the bigger 15" package, I don't see why it wouldn't work!"
Without trying it first. The reason I'm saying this is when I called with my problem of the motor hitting the tire, they were baffled and had to go in the back and bolt one up. Then they came up with the idea of shimming the motor and having the little gear only catching half way on the big gear, without a true test to see if it would work, again they said
"That should work!" Well before I pulled the big sprocket off I check it to see how true it was, well it had a little wobble, that's making matters worse! When I talk to the factory they said half of a gear is OK. So I said "Man that's only
1/8" of an inch of gear meshing!" He said " It's low speed and 'should' be OK" I said "But we're looking at over 1200 lbs of weight it has to deal with, plus only 1/8" of clearance between motor and tire, The rubber tire will flex and easily take up that little 1/8".
I don't want to take a chance of the motor or other parts coming through my fiberglass finder at 70 M.P.H.and screwing up my $750.00 paint job! He said "The motor would 'Just' rub on the tire."
I'm still looking for the studs to finish the job and get this kit on the bike, I'm off for a week and can't and won't wait for Tow-Pac to come up with a better idea, to fix their screw up!
Oh, I almost forgot to mention that the lead weights on the inside of the rim are only a hair away from the motor's shaft, as it would spin by the motor at neck breaking speed as you go down the highway ! what would happen if they would collide? Weights fly off or motor damage!
I can't help but wonder??? Am I the first to get the reverse on the bigger kit???
Spacer gave me the clearance I was looking for. Also I still have a Full gear mesh!
Days off start next Wednesday, so I will have time to get things together!
Lets hope it gets easier!
***After more examination I will have a good 1/2" of thread make-up on the 5 lug nuts without getting longer studs! Will that work for a wheel that is not a drive wheel, that just follows along taking some of the weight?***
Today I have a music Gig to do, may get back to it this Sunday.
When the problem is fixed it looks so easy! Hindsight is 20/20!!!
Reverse Gear
I am somewhat confused on the reverse drive setup.
Please excuse me for a poss. "Dummie Question", But does this reverse drive stay engaged on the ring gear while traveling at normal or worse, highway speeds?
I can't imagine that little gear or motor spinning constantly.
Sorry for a stupid question if I missed something.
It's engaged and disengaged by a spring lever operated by your foot 'heel'. Up engaged Down disengaged. Then it's turned on and off by a switch at the left finder!
See the two springs and part of the long rod! It's facing up in the picture. Should be horizontal.
In picture two you can see the round rubber foot control opposite the motor on the front, it's in the engaged, locked position. As you can see It locks is position. You could screw up and leave it engaged, no safety warnings to let you know if you forgot it engaged!
Bob,
Does Tow Pac indicate at what speed the bike backs up and what the duty cycle is on the motor??? Wonder if there is an over current or thermal cut out within the motor itself??? Is there a switch up on the handle bars you push after you step on the little rubber thingy???
Les
Les
I'm not sure about the duty cycle or over current or thermal cut out within the motor .
It's operated by a switch that lights up when turned on, attached to the left finder next
to the reverse Heel lever. It backs up very slow, 20 ft. per minute, also can't
handle more than a 3 degree incline or a passenger when in reverse mode.
You find this out after you get the kit not before. Everything so far about This
experience has been vague and a joke. But it is not funny at all to me! I've
been working hard to get it to work. I have a lot of Money involved. I
almost call the credit card company that I used to purchase this kit and tell
them I want to return it. That was before I figured out the reverse problem.
Now I have the parts being painted, I call the painter to cancel the job but he
had purchased the paint and started sanding the finders. I did leave a nasty
message on Tow-Pac's cell telling him to call me ASAP because I was going to
call the F%$#ing credit card company. That was last Friday when they left me
hanging all day waiting for them to call! They got a chewing out due Monday if
they will talk to me! I still have to put the kit together and Test and Adjust
everything. As you can see everything so far has been a Big headache! After
my kit is together and tested I will give a Review for Tow-Pac not before. If
thing don't get better I will blast them all over the Net with a You-Tube video
and use google! For their sake I better be satisfied with the end result!
:Crap: So far!
They did send the two missing spacers they left out , so now I can finish the "Receiver
Hitch" installation. That's the part that stays with the Motorcycle! Now all I have to do
is torque the bolts after using Red Loctite on them. I'm not getting that from Tow-Pac
It's my idea as these parts will not be removed every time I go two wheels!
I like to do things better than right, as you can tell by my post on this job!
I was expecting expert advise from the factory!
That didn't happen! You are on your own with this kit!
I hope these post will help others, If you go Tow-Pac you will know what to expect.
Also I hope to work out all the bugs so the next guy will have an easier go at it!
The basic kit and fender design looks real Good to me. Too bad Tow-Pac can't hold on to the
Ball!
Your experiences with this kit are better than any review you'll ever read. Real world experience start to finish. I've kicked around the idea of putting something like this on my Kawasaki. It definitely won't be a tow pac. That reverse sounds useless for that gradient and no passenger.
Almostagamer
