Mufflers Tips Scraping.
Sep 15, 2013
145
26
Astoria, NY
Bill
2013 TG with 1.25" rear lift and 4" SE Cannon mufflers with Short Slash Up/Down/Out end caps. The bottoms of the end caps are scraping each time the trike goes over a speed bump or going on the table lift. Any fix or other end caps to prevent this from happening?
Kind hard to believe you are scraping with a lift kit on it, did you put the lift kit on or was it on when you bought it, the reason the person you bought it from said it had it and it doesn't if you are scraping. The only way to not scrape would be if possible take the speed bump at a angle or slow down over them, you must have some really tall speed bumps there, we have at certain places here but I don't scrape at all when my 2018 was stock and I now have a lift kit that I installed from DK customs. You might want to check to see if you are low on air in the shocks, just a thought.
All for now Trampas
P.S. Not all lift kits are the same, just saying
I seen your pic on the hdforums, looks to me like you have no lift kit at all, your muffler tip is way to close to the floor and it looks to be a cement floor, also looks like you have no air in the shocks, you really have something that isn't right IMHO, muffler sitting to close to ground and I can see why you are scraping, you need to get this fixed or take it someplace to have it done, if you put the lift kit on I'm beginning to think you put a lowering kit on by the looks of that picture instead of lift kit
All for now Trampas
Wingnut21
