- Thread starter
- #21
Hi Jaysgone. I used to drag race for yrs growing up. There is a safety thing you can install on your Trike. Its called a DRIVE SHAFT LOOP. All it is . Is a U shaped piece of steel that bolts under the drive shaft to the frame. To catch the drive shaft if it breaks. So it won't fall and hit the pavement. It keeps it in the loop. It has saved a lot of Hot Rodder and a drag racers lives. You might want to check on this for you owners with drive shafts. Might be a little different on a Trike. R/TThumbUp
I know my trike has the drive shaft loop.
That's one of the things Chuck had to redo on my trike yesterday.
He said the original installer didn't even bother to center it. That might have been part of the banging I heard.
I don't know if it was MT or the dealer.
But they said if I had continued to ride it the way it was.
It might have also damaged the Honda transmission if it failed, also said my exhaust pipes weren't as far as he knows Motor Trike OEM???
