Low Beam Head light Adjustment
Mar 22, 2013
394
51
Thonotoassa, FL
Doc
does anyone know if there's any adjustment to raise or lower the head lights , I need to raise my low beam a couple of clicks , the high beam is fine ,but the low bean hits the ground about 25-30 in front of the trike ?
Yes there is a headlight adjustment. You can either raise the hood and do it, or lay under the nose and look up to do it. You will see a threaded bolt on each side of the headlight assembly, turn the bolt accordingly. The end of the bolts have a very small socket fitting on the end which worked best for me. Hope this helps.
i'll take a look at it tomorrow , its to late tonight and its been raining cats and dogs all evening . Tonight was my first night out on it late at night where I needed to be able to see using the head lights , but not using the high beams, my only worry is the getting down under it and trying to see the screws that your referring too. As i'm still using a cane 90% of the time just walking as of yet...... any idea of the size and I assume their metric not SAE top for up bottom for down ?
3, 4mm adjustment bolts, the one on the top is for up/down adjustment. Put the hood up, turn on the light, place tape on the floor for a start point, mark a center point and adjust the top bolt to raise the spot about an inch.
tomg
mudrock
