Head light lens.
jeff i believe TBMS had them made for them. I've not seen them anywhere else. Might try a dealer and see if one might be available from the factory. they do not sell direct. I expect it will be expensive.
Good morning
I took the numbers off the front rubber that holds the light 50R00-1066 and it comes up as a light for a 500 atv. newer models have different lights so go look up numbers and see what you find. mine is #146 08.
Good luck
Dragon
Well after a lot of detective work I managed to find out that the high and low beam lights in the 2008 model year are made by Hella. The bad news is that they are discontinued and not in stock. In managed to find a set of NOS and changed mine out. If you are in need of light assemblies for the 2008 year you need to get in touch with Richard and order the new upgraded models. Some cutting of the fiberglass is required but it does not look too bad.
Dragon warrior
