Love jug question
nucseal
1000+ Posts
Staff member
Gold Member
Jan 16, 2012
1,149
1,420
San Antonio, TX
Pat
Since the LOVE JUGS was specifically design to aid in heat from the 88, 96 and 103. The 114 is supposedly to run 20% cooler than the 103 is there a need for the LOVE JUGS on the 114. Secondly, how efficient can the LOVE JUGS be with Milwaukee 8? Curious mind wants to know.
love jugs
Using the mighty mites on my 2015 Freewheeler caused the motor to be ruined by heat> The mighty mites fooled the temp sensor into believing the motor was cooler than it was.
Kevin @ D K Customs has done some in depth testing, Read here
I have at least a 30 degree drop in temp on my 17 M8 since adding the Mighty Mites
No air cooled motorcycle should be with out some type of fans to remove the heat IMO
  • Thread starter
  • Staff
  • #6
I guess, I will be putting them back on. Not looking forward trying to get the horn vibration isolation thingy off. Was a pain in the a$$ last time!
That rubber isolator can be a HUGE problem
I found a heat gun on the back side helps a lot to get it off without bad Ju Ju;)
  • Like
Reactions: MDO
+1 on using a heat gun. That is what I did when I put my Love Juggs on and I had no trouble getting the rubber isolator off.
Sunman
Great to know. I do that once everything comes down around here!
Boatpaddle
