How to wire up love jug
payzac
40+ Posts
Nov 21, 2017
42
33
Kettering Ohio USA
Hey fellows got mighty mite installed now need to know where to plug into have the 4to8 connector but do not
see where it goes. trike is 2017 need some HELP !!!
THANKS
Payzac
I wired mine direct to the battery. I use the switch to turn on & off.
On my 17 I had the additional accessory switches installed in the dash, then my mighty mites plugged in to the harness they came with and didn't need the 8 pin adapter.
The connection is right in front of the battery, it took me a while to find it after I had the dealer install the switches. One switch has the connector you need and the other one just has 2 wires you can splice into for another accessory.
With this setup the fans come on and shut of when you turn on the bike power unless you deactivate the switch.
Bob
2011Spyder*
