redneckray
Tour Captain
- Jan 27, 2010
- 442
- 0
Well just wanted to share with you on how i build a LL front end, this is going on a trike frame that i am building, there are alot of ways to build a LL, but this is my version of how i do it, i start off with 1/2 in plate and cut it to size 6 in x 12 in and mark my holes for the downtube and the center bolt[which will be 1 in and down tubes 2 in.
I use 2 in dom tubing with a 1/4 in wall [won't bend] here are some pics of it so far, will post more as i go along with the LL build.
The tubing is cut to length of 36 in. And will cut it as i know what wheel i will use and then make the rest of the ll brackets and then mount the shocks, this ll is going on a trike frame that has a rake of 50 degrees and will handle great on the roads.
