norm908
1+ Posts
Hi All,
I've always kept my bikes plugged into a battery tender whenever I would not be riding for several days. However, since retiring and moving into a condo community, that is not possible. So, after a brief illness, I went to start the Trike and it was dead. While doing some research, I came across a post on here recommending the EarthX quick connect cables. I thought they sounded like a great idea and ordered a set. After hooking them up, I went to plug the cable into my jump box (NocoGB20) and found that they would not plug in. Both the jump box and cable had female type connections. If anyone is using the EarthX cables, I would appreciate if you could tell me what jump box you use that will plug in to the cable.
I did have another thought about trying to use a solar powered battery tender. I bought a 10W, 12V solar power battery trickle charger. However, as soon as I plug it into the tender pigtail, the lights go out and it doesn't charge.
Anyway, I'm hoping someone can at least tell me what jump box I need.
Thanks,
Norm
Thanks,
Norm
