How to change tailight bulb on champion trike
Hello
My 1st post. I just bought a 2005 Honda Goldwing trike with a champion kit. I have a rear turn signal out. Can someone please tell me how to get the lense off, so I can change the bulb?
Thanks,
flyingjets
I don't have a Champion but I think if you look behind the rear from underneath, you will either see the bolts/nuts you need to remove to allow removal of the entire light housing, or possibly ..... just simply be able to rotate the lamp's rubber twist-lock and slip it out of the housing (with the housing still installed) allowing you to unplug the bad bulb and plug a good one in.
Then just reverse the above.
Gyl
