Can someone here please show me where I can bleed the brakes, front and rears? Pic's would be very helpful as well.
Thanks in advance
Thanks in advance
There is one bleed port on each rear wheel and two on each side on the front. If you have a mighty vac, it is a one man operation,
Location of bleed ports: On the front, if you look at the caliper from the side, you will see two small hex fittings, one pointing down, one pointing up. Same on both sides. On the rear, it needs to be on ramps to see them. Look on the back of each caliper, there is one bleed port on each one, they are larger ports than the front, about 5/16 I think. When I get to my PC later I will send a picture.
It's just in front of the left rear wheel under the body panel. Easiest way to get to it to replace is by removing the wheel. If you're just trying to get a charger on it, you could probably reach it without removing the wheel. I've replaced batteries in worse places before, but not exactly "easy access" either. This is probably why so many of them have remote terminals installed.
