Voltage Regulator Bleed Test
Jack Klarich
Guest
Oct 11, 2016
18,130
15,125
Jacksonville, FL
Jack
This test is often over looked and can drive you crazy replacing parts
[h=2]Regulator Bleed Test[/h]
  • 1 Unplug the regulator from the engine crankcase.
  • 2 Touch a trouble light to a known ground on the motorcycle and to the pins in the regulator plug, one at a time.
  • 3 The regulator is bad if the trouble light comes on. If not, reconnect the regulator plug to the engine crase
    ( trouble light should read test light)
Dan2003
