- Thread starter
- #21
Do you have to remove the inner fairing along with the outer to get to the forks? Thanks.
Just the outer fairing.
That may be above my skill level. I like to do most of my own stuff I have the manuals but a walk through
step by step would be a blessing:LordHelp:
I wanted to install the Progressive Monotubes on my 2008 Ultra trike conversion and in contacting them they said that my inner fairing and my outer fairing had to be removed. Is this true?
Yep, changed mine out last winter along with new progressive air shocks for the rear. Rides and handles much better now.
do you recommend new rear air shocks seems i'am always adding air after a 100 or 200 mile ride .
Why would you have to disassemble the fork instead of just pulling the front wheel, removing the bolt in the end of the fork above the axle, take the cap off the top of the fork & drain the oil. Then reinstall the lower bolt & replace the oil in the top end with 10oz of oil???? (wet fork)
Just wondering............
Naw their full of crap, the picture I posted in a reply above is how far I had to take my dads 09 Triglide apart to remove the fork legs. The one other thing I pull is the radio because sometimes you need to use a block of wood and a hammer to get the leg free. To pull the radio it helps to have long ball head allen wrenches.
Glad to know the truth. I have a rake kit on my trike. You think that it will give me any issues in disassembly?
