Thank You
Richard said the only grounds were by fuse box frame, and ground wire by pcm .
Dragon
Good morning
does anyone know where all the grounding points are on the stallion
Thank you
Dragon
Thanks guys
I am going to add a ground, I'm having problems with my air system and it just dumps the air and stays at zero so thought it was ground somewhere
thanks
Dragon
Thanks guys
thanks
Dragon
I had problems with the air bag system and I reversed the wires on the switch and it corrected my problem. Why ? But it worked for me. If that hadn't worked, I was going to switch the wires with the pedal controls to see if it was the switch. Those are easy trouble shooting ideas. Good luck.
Tomg
