Greasing Lehman Monarch II trike
Aug 22, 2014
13
3
Gravette, AR
finally found grease fitting for the rear u joint everyone talks about. Now how do you get a fitting on it? No room for a grease gun short of taking it apart that I can see. Any suggestions would be appreciated. Also this is on a 2010 GL 1800.
Is there more than one point on the rear U joint that needs to be greased? How about the front? I bought the grease gun and plan on doing the work this weekend. Thanks.
On the Monarch II there is only one point where greasing is necessary. The front joint is the OEM Honda joint and is not able to be greased.
Boatpaddle
