YES It will tell you when fuel is getting low. You have an odometer location indicator option that tells you miles left to empty (toggle left grip top button).
Boborag:
You all need to remember there is a thing called usable fuel. Especially if you change the angle of the tank. You may not be able to get at that whole 6 gallons. The only way to know is to run it out of gas and have 6 gallons available then to fill it up. What it does not take is the amount of gas that the pickup tube was not able to get out. The amount you did put in was the usable amount.
If you put a DK Custom tank lift kit on, it changes things. I can typically ride till it goes to Low Range, then ride another 10 miles before gassisng up, and it will still only take a touch over 5 gallons. Haven't pushed it further (really don't want to push this thing), but the lift kit changes the angle of the tank, so it reads low a little quicker. Have just never checked my mileage or range on a tankful, I am just having too much fun riding the damn thing!
With the Tank lift and the Deluxe option, you will have a full 6 gallon of usable fuel on all years of the Tri-Glides.
On the 2014-2015, the filler neck was changed, making it difficult to fully fill up the tank, whether or not there is a tank lift. The solution is to rock the TG side to side to get it to burp, allowing for a complete fill-up. (front to back rocking does not work as well)
On the pre-2014's, as long as you have a deluxe option, and no taller than a 2" tank lift, you will lose no usable fuel capacity.
On my 2011 with tank lift and deluxe option, I filled up several times a bit over 6 gallons.
On my 2014, after I learned about rocking side to side, instead of front to back, I've been able to fully fill up also.
The deluxe option lifts the back of the tank also, so it stays on the same plain as it was before it was lifted?
