flat tire
Has anyone ever had a flat tire on one of the voyage kit tires. How does bike respond and what is correct way to remove tire if you can't plug it. Just thinking out loud.
oldmanonavtx
I guess if someone sits on the opposite fender you just take it off. I don;t imagine you would notice anything . There is very little weight on them
Look under the trunk.On the tri-glide there is a crossmenber there you can put a<br />
5"Height 8"wide board between the frame and your 2 ton car jack. i also use a small jackstand to fit under the rear bumper brace, for support. i keep the small board in my trunk, so if i get a flat tire. all i need is a jack & lug wrench. the lugnuts are 3/4".<br />
i hope your trike is simular. i tried to use a 4 wheeler jack under the trike, but the center of gravity is too far back. all i did was jack up the ft. tire. good luck.
I know it is hard for an old man like me to put the wheel back on, nothing to keep the hub from turning. I have a friend who had a flat on her Shadow with a TowPac kit. The rear MC tire went flat and no place to get a replacement, she rode it about 75 miles on the flat to the nearest shop and replaced the tire.Took a while but she got there, on the Interstate too.
ledgin
