DK Custom Products
Sponsor
Electric or Mechanical Reverse, which do you have, and which would you prefer?
I think HD should have designed a mechanical reverse to begin with
The 21 model year has an improved electrical motor now so we will see how it pans out
I have an ESP if it goes out, I do not use the reverse unless I absolutely have to
That's "improved"? I'd hate to see what came before it then. My reverse is weaker than a soup sammich.
Technically The reverse electric motor is a reverse assist it is not a reverse as in any motor vehicle my ATVs and my side bys all come with mechanical reverse can you imagine buying a $20-$40,000 vehicle and then the instruction says just don’t use it for more than 5 or 10 seconds ……
The electric motor has been upgraded, is it better? I dunno, for what it is it aint bad, but it should have been mechanical to begin with.
Reverse is NOT a new subject to The Moco, side car bikes and The Servicar had an actual reverse gear in the trannys for crying out loud.
Put the Motor Trike in at 17K when the electric failed. Didn't give H-D a chance to fix it. Go backwards anywhere I want to and how fast I want to, for as long as I want to!
Do it right. Motor Trike mechanical reverse.![]()
