Electric connection / Ignition on only.
rmrc51
Lost In The 50's
Feb 2, 2009
4,177
130
Palmyra, Virginia
Once again, me being the new kid on the block with the Valkyrie, another basic question.
I'm installing a Cobra Light bar along with a few other electric options. Where is a good place to tap for switched power? (Ignition on only)
I'd rather not add to the mess inside the head light if possible.
Thanks in advance.
If u are hooking up lights like driving light you need a relay. You can draw the real ( main 12V that power the light) 12 Volts off the Battery or fuse block and the excite for the relay off one of your clearance light (side marker, tail light etc,)
MrArcade
