Drive Sprocket Replacement
I have a 2007 Harley Street Glide with Champion Independent Suspension conversion kit. The kit has over 30k since install. The drive sprocket teeth feel like shark teeth and belt jumps teeth when romp on throttle. I need a new sprocket
Ron, Are you asking where you can you find a sprocket.:Shrug:...Also you'll need a new chain!
Ron is the belt adjusted correctly? If it to loose it can jump. Bottom run of the belt in about the middle should only be able to push it up about 1/2 a inch with about 10 lbs of pressure. How many miles on the belt? Should be the same belt as before the conversion.
Belt tension is correct.
The sprocket teeth should have a dome shape on top for the drive belt to fit into and grip the belt. My sprocket's teeth are pointed which allows the belt to slip if you romp on the throttle.
Per Champion recommendations, I installed a new belt when the kit was installed. The new belt now has over 30k miles.
Ron, call Mark at Champion Trikes of Arizona at 480-597-3444. He should be able to help you with parts.
dhinzman1
