It's time to lube the drive shaft on my MotorTrike with aqua shields. Can I use a floor jack to lift the trike enough to get to the drive shaft. And, if so, where do I position the jack?<br />
Gerald
Gerald
don,t put to much grease,,,, too much is like not enough!!!!
How often should you lube the splines and do you use moly 60?
