Drive shaft grease
I don't have a Wing, but it's probably the same, anyway. I use regular lithium multi-purpose grease for the u-joints, but you could probably use just any kind of regular grease in these. In the splines however, I would recommend only a moly-paste, or the very least, a moly grease. You can buy moly paste through Honda. The reason for moly on splines is that's it's specially formulated to work with the pounding these splines take during running, (to try to make the explanation short... if you need to know all of the technology involved, you can look it up). Others may disagree with me on these points and that's ok. This is what I use and for a very good reason. Happy and safe riding.
Thanks Chum!
dyno56ca
