Thanks Stinger! ThumbUp
That looks like a great kit and it looks complete. Where did you insert the Willwood presure valve?
Same varga style 2 pin calipers and same rotors as all the rest of the generic kits.
The only difference that I know of in any of the generic kits is the caliper mounts. I was warned about the stamped bracket, so I got the forged bracket.
As long as the stamped bracket is dimensionally correct (alignment) it should be fine on our light weight app.
Check the thickness of the brackets to the removed back plate. Shim or machine as necessary.
Check the caliper alignment for twist. Not sure how to correct this with stamped.
Check the caliper alignment for centered. Shim or machine the spacer rings on the axle.
There are numerous different depth of axle end castings and bearing caps. The generic kit is only made in one of the possibilities out there. Make sure it assembles right. Sometimes it is a straight bolt on, sometimes not.
I bet they come real close to a bolt on swap on a later irs.
