De-cat question
RKplus10
300+ Posts
Mar 17, 2018
463
456
Waelder, TX
Roy
Thinking about removing the catalytic converter on my Freewheeler. Does anyone know what material is used on the OEM head pipe? What type of wire should I use?
2015 Wire for MIG. Many vehicles use stainless steel. I'm thinking Harley uses mild steel that's plated.
I didnt go out and look , but just welded with the wire that I have on my little mig for welding everything, Its just regular old steel. Just cut a window out of the top. Air hammered and pried the guts out and welder the piece back in that I took out. Only took heat shields and rear floor board off. Did my last bike the same way...
OK, Thanks Lyle. You make it sound easy.
Got it done, the cat is gone. Kind of cool out so I only rode about ten miles but I'm digging the sound. Stage 1 with Pro Super Tuner and Monster Rounds, tune seems fine. Time will tell if changes are needed. Thanks for the help guys.
Deznan
