dash lights
Feb 19, 2008
727
59
Imperial, MO
Tom
I purchased a 2010 Stallion and the dash lights are not working. I checked the fuses in both fuse boxes (under the hood and under the seat). All fuses are good. If the bulb or bulbs are burned out, How do you change them?<br />
The owners manual has nothing in it about bulb replacement or a list of what bulbs are used on the vehicle. <img src="images/smilies/shrug.gif" border="0" alt="" title="Shrug" class="inlineimg" />
I spoke to Richard at Thoughbred Motor Sports (TMS). After speaking with him, he instructed me to test the voltage on the Brown wire with the white tracer (stripe) plugged into the back of the headlight switch. While the headlight switch is turned on, I got approx. 12 volts. That ruled out a faulty swictch.<br />
Richard concluded that the module in the dash assembly is bad. He is sending a new dash gauge assembly <u>all under warrantee</u>. There are no light bulbs in the gauge cluster. I think they are LED's built into the circuit board for the gauges.<br />
Thoroughbred Motor Sports (TMS) are the best. <img src="images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<img src="images/smilies/smiley-score010.gif" border="0" alt="" title="10" class="inlineimg" />
Stitch61
