CSC Reverse
Oldrodder
80+ Posts
Mar 26, 2018
82
93
Sudbury, on. Canada
Mike
My "new to me" trike is a 2010 Kawi Voyager with the Kruze kit. It has electric reverse. Does this system have a speed reversing sensor? After activating the switch, mine snaps you back as you engage the reverse via the starter button. Is this normal??
TIA.
TIA.
I don’t know if it’s normal for your unit but on my Triglide It can get a little Abrupt when you hit reverse..
my CSC does have a snap to it when you hit the button if you keep the button pressed it equals out, the first few times its a little weird, It works great .
Mike, yes that is normal. What I do is put the rear brake on, then activate the reverse button and hold it down, then let up on the brake peddle slightly to engage the reverse. Comes on a little easier with some brake drag. Will at CSC suggested using reverse in that manner.
Thank you Doug. Sets my mind at ease.
Roger71!!
