my wife's freewheeler cruise control doesn't work. the light comes on, but doesn't set. is there anything I can check?
Gary i can't help you But i can and will Welcome you to Trike-Talk....:clapping:..
And i'm sure someone will chime in soon with the help you need...
Have a look here also
#1, very easy to break the front brake switch if 1 is not careful
Here is a picture of how to protect the switch when working on and around the switch
https://www.triketalk.com/forum/threads/44844-Front-Brake-Light-Switch-Caution
I was wondering if you would remember that diagnostic. That is a great tool.
We need to make that a sticky.![]()
Done.
Zook, I was referring to this diagnostic video on troubleshooting your HD cruise control system.
https://www.triketalk.com/forum/thr...se-Control-Diagnostic-Check-No-Tools-Required!
I think Jack is on the right track. I just got a cruise control working again by cleaning sockets and grounds and replacing the tail light bulbs. They were lighting up, but I thought they were ticking fast. The ticking slowed with everything fresh, and the cruise works now.
I recently sent my Tri Glide to the shop because it would not start in gear. Started fine in neutral. They said the neutral saftey switch was bad, but had to replace the left switch pack which included the cruise control. (Was covered under the warranty) I don't know if your switch pack could be the problem. Just a thought.
I'll check those out and get back. thanks
