A Quick & Easy Cruise Control Diagnostic Check-No Tools Required!
I learned a nice & easy way to test your cruise control circuit. I will link to a video at the end.
1. Make sure your kill switch is off.
2. Turn on your ignition switch.
3. Push your CC switch in to activate the amber speedo indicator.
4. Hold down your CC switch like you would to set it & flip the kill switch to run.
Your CC indicator will be amber & when you engage your clutch, front or rear brake or roll your throttle forward, the indicator light changes to green, signaling that that switch is functioning properly and all is well. I tested it on my 2017 Freewheeler & it worked great
Very cool.
[video]https://www.fixmyhog.com/video/harley-cruise-control-diagnostics-012749/?utm_source=newsletter&utm_campaign=A6136&vsoid=A6 136[/video]
Very cool.
