cruise control not working
Gary i can't help you But i can and will Welcome you to Trike-Talk....:clapping:..
And i'm sure someone will chime in soon with the help you need...
Gary Welcome to Trike Talk
Have you done any thing to the trike recently?
Are your brake lights working OK both front and rear brakes turn on and off brake lights?
If not you may have a brake light switch problem
Follow the below link to check your trike for stored error codes
https://dgcustomcycle.com/tech/harley-diagnostic-codes-04-present/
I was wondering if you would remember that diagnostic. That is a great tool.
We need to make that a sticky.:cool:
I remember because you posted it;)
Always like to read your input ( Very Valuable stuff) and I agree it should be a sticky along with a lot more info contained in these forums
IMO we cannot have enough info:clapping:
  • Thanks
Reactions: MDO
I think Jack is on the right track. I just got a cruise control working again by cleaning sockets and grounds and replacing the tail light bulbs. They were lighting up, but I thought they were ticking fast. The ticking slowed with everything fresh, and the cruise works now.
Jack has saved the day for many of us.:clapping:
Switch Pack Issue?
I recently sent my Tri Glide to the shop because it would not start in gear. Started fine in neutral. They said the neutral saftey switch was bad, but had to replace the left switch pack which included the cruise control. (Was covered under the warranty) I don't know if your switch pack could be the problem. Just a thought.
The Tri Glides seem to have a lot of problems with those left switch packs...Hopefully, they have addressed the issue.
Bullet Proof
