Good Luck!!!
most wire harnesses should have a industry standard color and should be really easy to follow. But yes to be on the safe side a volt meter/light will help.
Black to neg/ground-red to positive or each wire being tested. So if you push the brake pedal the meter or light will change state light on or meter 12vdc.
Was hoping the wiring diagram would help her out??
Good Luck!!
You would expect an industry standard but I've experienced everything but. A blue wire may be the left turn on one trailer and a yellow may be left turn on another. I just finished hooking up an isolator on my 2012 GL1800, the 5 wires on it had nothing in common color wise with either my Aluma MCT trailer or the 5 wire ribbon cable I installed. The harness I had on the 2010 Triglide I used to have was the same way, wires from the harness a different color than the trailer and ribbon cable.
