champion exhaust
Jun 12, 2020
11
7
houston,tx usa
I am trying to replace my pipes to a 2 into 1. I have v&h big radius and can not find a pipe that clears the champion kit. They all are either to long or turn up. the trike is a 2011 fxdf hd fat bob with a champion solid axle. Anybody got any ideas? Thanks DAGO
I have a Supertrapp 2:1 on my FXLR.
My kit is a Lehman but they are similar.
I mocked up the exhaust for routing and length and bought a piece of stainless exhaust (proper size) on eBay.
It was already bent 180 degree and I cut the middle of the bend and made an s-pipe.
It works and nothing hits.
Just an example:
https://www.ebay.com/itm/EXHAUST-TUBING-Mandrel-Bent-180-U-2-25-inch-409-STAINLESS-16ga/170187587537?epid=19008318652&hash=item279ff87fd1:g:CYIAAMXQ2q9Ra7mF
https://www.ebay.com/itm/2-1-SuperM...134375&hash=item48e415bad8:g:ayAAAOSwf1RepJ80
https://www.ebay.com/itm/2-1-Black-...b7eea52:g:Ll0AAOSwEtxfDJJt&LH_ItemCondition=4
Lee, thanks for the links and picture.
Is that a ss trap or cs? I do not have a tig welder.
What if anything did you do for a heat shield?
Did you have to change or modify the mounting bracket?
That offset looks like a pro did it. You are a talented man my friend. Thanks DAGO
I was able to fit it without modifying the collector tube.
I have a Stainless version of Supertrapp that is no longer made.
The heat shield was a modified heat shield that I had hanging around the shop.
Just dresses it up a bit.
Your exhaust is mounted to the engine, so any brackets need to be free-floating.
I used rubber bushings on the rear hanger.
Thanks again for the info.
It gives me an option on how to plan this mod.
You did a nice clean job on that trap set up.
How many discs do you run?
I ran one on a evo and loved it. THANKS AGAIN DAGO
I am running between 16 and 20 discs. I had a racing cap on it and put the standard one back and added 4 discs. I haven't run it enough to read the plugs or even do a real tune on the carb and timing. No DYNO for it yet......
OrlandoQui
