I have a 2005 Ultra with the Lehman conversion with 20K on the clock. The dealership had installed big bore 103 engine kit with a street legal 203 cam when the conversion was made. The trike has a 5 speed tranny.
At present, the engine doesn't like to be in 4th or 5th gear unless the tach is at least 2,000 RPM. I would like it if the engine could deliver higher torque at midrange. Others who own (newer) trikes tell me to cam, cam, cam.
I spoke to Bob Woods, and he recommended a Knight Rider TW555 cam. Andrews said to leave the 203 alone and ride it as it is. A good friend and excellent mechanic said I should change the five speed tranny to a six speed. As you can see, confusion reigns supreme.
I have read many horrow stories about premature cam chain tensioner failures on this engine. I know that I have to inspect the cam chain tensioner pads before riding. I will have to take the cam cover off anyway, so while I am in there, I would plan on changing the bearings, cam support plate to the S&E support plate with hydraulic tensioners, and high capacity oil pump.
Four questions I present to my fellow trikers and mechanics:
1. Would you recommend a cam change, and is so, what cam would you recommend for this ride, and why?
2. Do I have to pull the entire exhaust sytem to remove the cam cover or just the front header pipe and brackets? If I have to remove the entire exhaust system, I am reluctant to undertake this job in my garage.
3. Are there tricks to the trade for removing the header pipe?
4. Any thoughts my plans to change to the S&E support plate and oil pump?
Any help would be appreciated.
