Brake Lights
I would first pull the wire connections from the pressure switch at the rear master cylinder. See if that turns off the lights. If it does, then apply front brake lever and lights should work properly. At that point you’ve found a bad pressure switch (which is a pretty common problem).
My wife's brake lights don't work. Flashers/turn signals work. Changed bulbs. Must be a sticking switch. Cruise control won't engage either.
The pressure switch for the rear brakes is right next to the front exhaust pipe, not a good place for the switch, HD has had 3 upgrades to this switch, it is not in as very user friendly place to change without using some special tools, but you can check that switch for trouble codes to be sure that is the problem child
I replaced the switch on a friends TriGlide. I’ll admit it was a bit of a challenge. On my Freewheeler, it looks to be a much easier. I only lost a few drops of fluid and it wasn’t necessary to bleed the brakes.
I have done this before also and did not have to bleed the brakes, it would not hurt to do this if you cannot remember the last time you bled the brakes tho, fresh clean fluid = better stopping power
Hi Lucy Welcome to Trike Talk
You have a bad brake light switch, if you look at it you will see why they go bad, no one but Harley would put a switch where they did exposed to such high heat
The engineers at Harley had to be really stupid to put a switch next to the exhaust pipe. They did this to the touring bikes too. Right next to the converter on my 12 streetglide. Bunch of dummys.
Harley had a recall on some of these switches for 19-22 models, IMO they should have recalled ALL of them knowing the heat would cause early failure, instead they chose to upgrade the switch instead, I think there has been at least upgrades to this switch
You may plead your case with your local service manager, they may choose to good will a newer switch for you
Stitch61
