2015 Free Wheeler Park Brake wont hold
Red sport.
60+ Posts
Sep 12, 2019
66
109
Winfield, AL
James
Need advice, just notice park brake on my 2015 FLRT with 34,000 miles on it don't hold any more do you think it just need adjusting or does it have any thing to do with rear brake pads?
Whens the last time brake pads were replaced? The wear is easily checked with a flashlight thru the indicator window on the caliper. You can adjust the brakes with the wheels on the ground. Locate the rubber boot just behind and below the brake pedal. Pull back rubber boot. Loosen jam nut (14mm) Apply pedal to first click. Does trike roll? If it moves freely- release pedal and lengthen adjuster(13mm). Push pedal to 3rd click. Trike shouldn't roll. If it does turn adjuster clockwise. Apply anti seize lube to threads. Due to age of trike I would check disc runout. Use Permatex Silicone Extreme Cerramic Brake Parts Lubricant pn:80653 ( orange- NOT PURPLE) on caliper pins and pad backing. Change your front pads too.
went to a indi shop they adjusted it charged me 65$. wished I'da went to my Harley dealer.
Desertgecko
