Boom Box 1.18.21
Apr 14, 2011
60
13
Great Bend, KS USA
Harley finally has update.
Has anyone installed update? I have downloaded guess I'll try this afternoon.
Getting ready to leave for Arkansas to see trees.
I'LL KEEP YOU POSTED (LETS HOPE)
That would be 1.18.2 :xzqxz: and I will give it a try also.
Thanks.
Bob :Dorag:
Update: Install went fine. My update was form 1.18.1 to 1.18.2
Everything still seems to work OK. Below is still true
Do you have to unzip the file on the USB stick before you plug it into the bike? I downloaded to my stick, then plugged it into the bike and got a message not an audio file.
I have a question regarding doing the update. I have done three updates in the past and have had no problems but I noticed some people are doing something different. In the past after I have downloaded the zipped file to my computer and extracting the file I would copy the .iso file to an empty 8gig thumb drive and then do the update on the trike. Now I noticed there is also a .txt file. I have never copied the .txt file, only the .iso file. Others have said they copy both to the thumb drive. I looked at MOC website and they say copy FILE not FILES. Should I copy both files?
Good question. But I have always done it just the way you have.
All update iso files are named EXACTLY the same on every version (swdl_boombox_6.5GT.iso). YES that is the only file you need.
I put them both on the flash drive after unzipping so if I look at that drive I EASILY know what version iso update file it is by reading the txt file.
The txt file is not needed to do the update!
Bob :Dorag:
Bob :Dorag:
I have looked at both those files and do not see anything that would tell you which version you are using. I see the version number in the zip file folder. I do know that all the update files are always have the 6.5 because it tells you which boom box it is for but the .txt file and the .iso file have the exact same file name
OK, now I feel like a dufus. When I click on the txt file it opens and shows me the info. I always have created a new folder for each update and named the folder the version of the update. Thanks for your help.
Sorry I was not clear ..... Yes both files when unzipped are the same name as previous versions.
I read the txt file. It has the P/N and version in it. ThumbUp I do several of my friends updates so I have a few drives.
Open newest txt file and it reads:
Boom! Box 6.5GT - Domestic
H-D p/n: 76000076
1.18.2
Bob :Dorag:
tony29
