rocket1lf
450+ Posts
Just got back from a 2000 mile trip up in Colorado. It did rain for several days. The only problem I saw from the rain is the LED indicators for the voltage and air bags started flashing from dim to bright. After the rain, they worked fine. I have the old style cruise control/brake light switch and it worked fine.
The bigger problems I have are:
1: The ignition switch has to be turned very hard against the stop to get it to engage and start the engine. Any suggestions?
2: The cable on the trunk key broke and I wasn't able to open the trunk. I finally figured out I could get to it by taking out the license plate light assembly and getting to the cable with an offset pair of needle nose pliers. I was able to grab onto the cable and pull it to open the latch. For a temporary repair, I put a cable tie onto the emergency release handle and left that hang out from under the trunk lid. I was able to release the trunk by pulling on that. This was done in the rain. What fun.. Anyway, does anyone know if the cable can be replaced or if I need a new mechanism? If I need the whole thing, does anyone know which Ford one TBMS used? Has anyone replaced the original one with a remote operated one? What did you use in place of the rivets that needed to be drilled out to access the mechanism? Thx Rick
