Anyone seen or ridden the new MT Gladiator
one thing to keep a eye on. is you air pressure in you suspension i was rideing mine with 32 lbs and hit some road construction and took off the two stabailizer nuts 5/16 bolt size, also i turned them around nut on top, i think they should had been installed that way in the frist place. there was four other bolts that i turned around also these bolts also hit but did not break . so two up at least 40psi . and no longer worry about 6 nuts hanging down a inch or so
Gyl
