- Thread starter
- #21
This mod which takes all of 5 minutes makes no sense to me.
What does placing a drilled nickel in the space do??
Is it the nickel taking up what would be a miniscule amount of space proving less fluid volume??:xzqxz:
While the shim kit adds volume???
By increasing the space.
There are 2 functional parts to the ADV
the top part = the plunger
The bottom part = The actual valve
The plunger is activated by you applying the brakes presses down on the actual ADV valve in the part of the fork that it is attached to below. So it is a plunger that is operated by brake pressure the presses down on another valve that controls Fork fluid.
By putting the spacer/nickle/shim in between the 2 units (plunger/upper & valve/below) you are moving the plunger further away from the valve so that even when it (the plunger) is activated it will not reach the valve that it is intended to activate. THUS defeating the ADV function...
hope that helped
