"ACC" Dash Panel Switches
keikat2
90+ Posts
Jun 9, 2018
95
52
Forney, Texas, USA
Hi,
I own a 2014 Tri-Glide with the Auxiliary lamps powered by the lower left side dash panel's left "light button" when depressed. As standard with the 2014 Tri-Glide, the left side dash panel's two right side buttons are non-powered "blank" buttons. I have a question concerning these two "blank" buttons. If I remove the two non-powered "blank" buttons and replace them with "ACC" power switch buttons, will I be able to turn my Love Jugs Mighty Mites cooling fans "ON" or "OFF" depressing one of the "ACC" switch buttons if the cooling fans are connected to the accessory plug behind the left side cover. Since the 2014 Tri-Glide's accessory plug is a 8 pin connector, I will have to use a 8 pin to 4 pin male plug accessory harness to install the Mighty Mites cooling fans 4 pin female plug to get power. Any help with this question, would be greatly appreciated.
Thank you,
Allen S.
Hi,
Thank you,
Allen S.
Utilizing the HD accessory switch Kit: https://www.surdyke.com/Search.aspx and the adapter: https://buylovejugs.com/index.php/product/8-pin-adaptor-harley-davidson/.
You be able to turn off with the acc switch and your fans will turn off with the ignition switch, without pushing the acc switch
Tom Wallen
