A new issue
Rogue1
400+ Posts
Oct 8, 2018
585
625
Ramseur, NC
Dale
Took my first ride after returning from Maggie Valley and riding with some of the boys. Motorcycle Mike, Zammy, Posse Rider, Mark H and anybody else's name I forget I apologize. While out and about I hit a few minor bumps and heard a clunk in the back end. First on one side then on the other side. Thought to myself I know what that is. When I get back home I grabbed a hold of the luggage rack on the tour pack and gave it a little shake. Clunk clunk clunk. Pretty sure it's pan hard rod. I just happened to have a new set of ends in my toolbox. I don't think it's going to hurt anything to wait till winter to pull that body off and change. But I will keep my eye on it. 35,000 miles
I put the Tri glide up on the lift remove the wheels and check it out. No lateral movement at all. I do have a little bit of rotational movement where the clevis is a bit sloppy on the mounting stud on the left side. Other than that I find no issue. I think that's the noise I'm hearing, when you spin the pan hard rod itself front to back.
I have had panhard ends go bad...but, a similar noise can also be the Axle Bearing Retainer Plate, as I discovered prior to my ride to Bella Coola.
It looks like I'm going to be replacing the rotors and the pads when I do the hard pan rod. The discs are scored pretty good. I guess it's time.
Marks2024
