3 Honda Trike Problems in same week
May 9, 2011
16
bridgton me
I have a 2008 Honda Trike (CSC). 15K miles. This past week I developed three problems while on the road far from home base dealer.
1. Propeller shaft became stripped and would not turn the rear end. Have any readers experienced this problem and has Honda or CSC stepped up to the plate to correct situation?
2. GPS will not function. Does seem to be able to connect to satellites. Any similar problems or solutions?
3. Turn signals work when required but will not release automatically. Need to manually shut them off. Any similar problems or solutions?
Comments ,ideas or solutions will be appreciated. Thank you.
I had a problem with turn signals not self canceling. Found that the flasher button was not completely released (it was pushed in just a slight bit). Took my knife and pulled it out and turn signals worked like they should. Eventually replaced the switch. No more turn signal problems since.
Get a hold of Nancy and Stan At Mtn. Trikes in Waynesville North Carolina
(828)456-6427 They have the fix for your driveline and I'm sure they can help you with the other problems. Great people and good prices. \Best of luck. Alan
Flyboy7312
