2020 TGU steering "shift"
Sep 27, 2020
4
5
Sumter
On my TGU when I steer to the left or right, or even just going down the road the steering will "shift a little to the left or right (depending on direction I am steering). Even when just traveling down the road it will "shift" to the left or right enough that I have to correct it back to center. It's like it is extremely touchy.
Is this a flaw in the steering or a failure in the stabilizer bar that is attached to the forks and frame? Or something else completely?
Tire pressure is good and tread is new-ish. No visible tire damage or rim damage. Only have put 100 miles on it since purchase. 5500 miles on it when bought from dealer as used.
If this is your first trike , you may still be getting used to the handling characteristics. I find that little things like where the front tire is in relation to the crown of the road will make the trike seem "nervous". Also side winds will cause you move around more than a two wheeler. You should also check the wheel and fork bearings for proper adjustment and wear.
I had my front wheel bearings fail at 5500 miles.
Your 2020 trike has factory warranty on it for 2 years, swing by the dealer and have them test ride it to see what they think. This should give you peace of mind.
:welcome:to Trike Talk
I'll mention that to the dealer when I take it in, but I would expect that to be extremely rare for the bearings to fail at such a low mileage. I have been paying close attention to the road crown and wind effects and definitely have experienced both. I also have ridden on flat streets and no wind with the same "problem" with the front wanting to do what I call shift and you call being nervous. It's a lot like the steering on a car having play in it where you have to correct it back to center. Could this have anything to do with the sliding stabilizer that is attached to the forks and frame?
Going out again today, so I'm getting more data. Any suggestions of what I should look out for other than what has already been said?
Definitely taking in to the dealer as soon as my other bike is out (2007 FLSTC). Peace of mind will come when it doesn't act like it wants to take off in one direction or the other.
Thanks Jack
Having the front bearings fail at 5500 miles isn't that rare. My dealer had one in at 2300 miles and I believe someone posted their bearings failed at 3700 miles.
It's the junk Chinese bearings that Harley is using.
David,
I'd like to know what air pressure you are running in your rear tires.
I'd suggest you drop it to 22 lbs and see how that affects the issue.
I had the same thing from the day I bought, on the highway it was like there was 40 mile an hour wind gust , It got worst the more miles on it ,mine was scarry, I change the front tire to a Avon 91 it was like a new trike . maybe thats what you have ??
Thanks Jack
I'm with Jack. You are under warranty so have the dealer check it out. Could be a loose Panhard bar. With the trike sitting, shake it sideways and listen for a clicking. If it clicks, something may be loose in the rear suspension.
Kurt
There is a lot of good info in the replies thus far....I also found that by lowering the pressure in my rear shocks I relieved some downward pressure on the front tire creating a balance front to rear and solved a problem that I had with curves and tire skipping giving me better steering control.
Bullet Proof
