Just checked the adjustment on my belt & it appears tight. I have searched numerous sites but can find nothing on how to adjust the tension on the Tri Glide belt. Would appreciate advice.
the only way to tell is look at the belt and see if it is running in the middle your luck if it is. I have looked at several and most run on the inside of the pulley on the edge. Wearing the side of the belt. When I had mine I aligned it to the center. Only if it's ridiculously tight it will ruin bearings in the differentialI agree the belt seems tight from the factory. Put just under 30k on 2018 TG and never touched the belt. And yes it was tight. Same on my 2020 - belt is tight but I’m not touching it. Adjustment seems way complicated and could get things out of alignment imo. If it ain’t broke don’t break it.
