Really don't want to start flaming HD but you guys should know the facts so here goes.
The parts are being "shipped" to the dealers the week of Oct 21, not received.
Most all dealers do not receive their orders until Thursday of each week.
The bikes in stock at each dealer will be fixed first. HD will not allow dealers to be left without bikes to sell.
The bikes owned and brought in will be repaired first come, first serve after the floor models.
Due to the volume of bikes being effected (I heard up to 60,000) the first shipment of repair parts will be limited.
I also hear the hydraulic clutch issue is based in the reservoir at the clutch lever. The issue will mostly effect two wheel bikes. When on the jiffy stand the fluid port falls below the fill line. When you pull in the clutch lever while on the stand air will be introduced into the hydraulic lines. When this happens the clutch may not disengage. I've also heard this is a overheating issue on the hydraulic line...doubt that is the problem. Have heard a few variations of this but the air issue makes sense and was repeated to me a few times by different sources.
There is a separate issue with the radios. These issues cause the communications center, blue tooth, CD and even the navigation system to lock up the radio. The issue is in the ECM and BUS module code. Therefore a new flash to the ECM will need to be installed. I have not heard if the code is ready at this time.
There are two colors of radiator caps. Blue and Grey. Seems, and I don't know which color goes where, the wrong color was shipped to the Water Cooled plant. (York). The Water Cooled Touring bikes are rated at 20# of pressure. The VRod is rated at 12- 15 #. Seems some of the Water Cooled Touring bikes had VRod caps installed by mistake. The VRod is made at the Milwaukee Plant.
All this information I have here is subjective to the people I get this info from. I don't get it from one person. Several contact me to discuss and this is an accumulation of what I perceive the facts to be. Sometimes you must read between the lines but when all say the same... I think you have a fact.
The rest is posted above... A&S clutch basket (Assist and Slip)
