Sissy bar mount bolts.
Wow, I thought you could get to them by removing the seat. Now I see those rear bolts would be near impossible to reach.
I would like to remove the body on mine one day to level out the rear. How many assistants did you need for the job?
None. I rigged eye bolts to the rafters and use ratcheting tie down straps (4) to lift the body up then roll the chassis forward. 1 each on the handles and 1 each in the muffler cutouts. Use strips of cardboard and lots of painters tape. Especially in/ on the wrap around louvers around the exhaust. 4 bolts bottom of trunk to frame. 2 forward bulkhead. 1 each side under the sidecovers.if you have a bumper that has to come off. This is also a good time to add slip ons if that's your intent.
I think it would have taken me 2 people. I did not remove it, but it’s 8 bolts and pretty straight forward. I was able to get some lumber under the fenders to raise it enough to get a hand in.
KMRolling
