Brake Pad Part Number '04 Goldwing/Roadsmith
Grandpot
20+ Posts
Aug 21, 2023
29
28
Fort Mill, SC
Keith
I have a 2004 Roadsmith/Goldwing conversion. Serial number, ST18F04025. Does anyone know the part number for the rear brake pads?
Thanks,
Grandpot
Not knowing when your Roadsmith kit was installed. Kits installed after March 1st, 2011, the rear brake pads are VW part number 311-698-151B. You can also call Roadsmith and they will be able to help you.
800-331-0705
Grandpot, I just went through this on my 2005. According to the Roadsmith manual, the same trike kit was used on 2001 through 2017 and they listed replacement rear brake pads at Autozone under PN D21EBC. I purchased a pair and they were an exact fit. I would also suggest suggest pulling out as much brake fluid out of the master reservoir (turkey baster at Dollar General) and replace it with new Dot 4 fluid.
Here's the info from the manual:
Brakes rear:
11” disc dual piston calipers
Brake pad
Autozone D21
EBC DP105 or DP4105
Calipers
VW 311-615-107 (L)
VW 311-615-108 (R)
Application:
VW Beetle Type 1 front
Rotors Roadsmith 113-615-601TS5
Brakes rear:
Brake pad
Autozone D21
EBC DP105 or DP4105
Calipers
VW 311-615-107 (L)
VW 311-615-108 (R)
Application:
Thank you for the detailed information.
Grandpot
John_C
