PanheadSteve
100+ Posts
This has been quite a journey. I hope you’ve got it resolved finally. At least there is plenty of time to check it out and be sure before your trip. Happy trails.
Took off hoses. Maybe slightly less drag. But I don’t think it is bad hoses.Bleed and flush again.
test ride. Seat of pants feels better. Fuel readout seems better. Temp gun after 25 mile test reads 80/90 had one spot 107. Further testing to follow,Just beat the rain home.
I just don't think those are high temps ? take your car for a ride see what they are, I bet the rotors would have to be in 4-500 degree range to warp the rotors? watch any type of racing motorcycle or car the rotors will glow red there well over a 1000 degrees . Thats my thought.Out for a ride Today. MPG is as normal as it’s ever been. Right rotor hotter than Left. Temps on left 107 temps on right still 120/130. So I’m saying I guess I still have some drag. It does seem to rule out master cylinder and upper hose. Could still be the right half of lower hose. I’m going to reclean right pistons and see.
With the ABS you will need a Scanner to energise the module, nothing else will do to purge all the old fluid outI had some issues on my 14 , replaced the rotors, took the calipers off cleaned then wit a toothbrush and small cylinder brush… it warped the rotors. Had the rotors turned just enough to get them straight. Cleaned again. Then I never had any issue after that. The braking system on the 21 is so much stronger but I dread the Day i need to bleed the system with the linked and ABS system. I probably will have the dealer do it or somewhere with the proper tools.
Might let the dealership do that for me.With the ABS you will need a Scanner to energise the module, nothing else will do to purge all the old fluid out
