Good choices SteveOn my 2017 trike I went with a S&S 465 cam, S&S premium lifters,S&S lifter cuffs Fullsac Sport headpipe, TTS tuner with full dyno tune, Screaming Eagle mufflers and a Screaming Eagle air cleaner. For my riding style I couldn't be happier, with 100 ft lbs of torque at 2300 rpm, this combo is perfect for two up riding while pulling my trailer. I can run along at 60 mph in 6th gear and roll the throttle on and it pulls without having to down shift. If I need to pass quickly downshifting is required though
When it comes to cams, if you want a badass thump, you will need to go to a higher duration cam. But the more duration the higher in the rpm range before you get full benefit from torque, so it's a tradeoff of sorts.Im looking to upgrade my M8 107 and wanted opinions on cams and exhaust to use. I want more tourqe but also want it to sound badass as posssible. I would appreciate opinions on set up and whats needed. I appreciate it.
