Stallion Heater Fan Motor
Dragon
250+ Posts
Dec 28, 2010
294
82
Oly, WA
Chuck
Good morning
I haven't seen this one posted. My fan quit working so I thought it would be a afternoon project to get fan out. I have a fiberglass body don't know if there is more space in abs body. there is no room took me 2 hours to get top bolt out, there is still no room to pull fan out hits on the inside of fender. I got Dremel tool out and ground almost an inch off fan housing, still cannot get fan out. body was put on after the heater system was installed:mad:. so I guess at this point I have to raise the body to get clearance. Does anyone know how to take the body bolts out or where they are:xzqxz:
Thanx
Dragon
Good morning
Thanx
Dragon
There is a video that shows removing the body on a 2008. I’ve tried to find it again with no luck. Perhaps you will have better luck if you try searching.
If I remember correctly lifting the body was not that difficult a process but the body itself had some weight to it.
HLG
