Dimmer switch for dash lights?
W3JNP
100+ Posts
Nov 22, 2016
153
137
Reading, PA
John
Dimmer dash lights.
Just brought my new to me 2008 Stallion home today.
The indicator lights on the dashboard are bright when I first turn the key on and the system does its’ self-check.
Once underway the lights (high beam – turn signals – cruise control – etc.) are so dim I can’t see them.
In a car I’d adjust the dimmer switch but I can’t find one on the Stallion and the owner's manual makes no reference to it.
Does anyone know how I can adjust them brighter?
THANKS in advance.
sorry there is no adjustment to the instrument lights
at least none i ever found
Thanks. I'm going to see if I can find a wiring diagram. There has to be a source voltage that is reduced and I may be able to shunt it and use a dropping resistor to get the desired brightness.
Thanks. I just found a site online last night and downloaded both maintenance and the electrical manual's in PDF.
Just a shot in the dark here, but on a Ford ranger, I’m not mistaken. There’s a light sensor on the dashboard that automatically dims or brightens the interior lights maybe it was left off on the Stallion…?..
THANKS! I'll check for it.
Ron A
